Whatsinaname Posted December 9, 2014 Share Posted December 9, 2014 (edited) Is there a way to apply different settings for particles coming from different groups during the meshing phase? An Example: I've got a particle system, consisting of three groups: Starters, Leaders, Trails. Now, I do not want to see any of the particles in Starters, want those in Leaders to be meshed with a slightly larger radius and the ones in Trails with a smaller radius. In order to mesh the particles, I basically use a VDBfromparticles SOP, filter those using VDBReshapeSDF and VDBSmoothSDF and then use a convertVDB in order to create polygons.I know I can maks certain areas of the mesh but it was way more convenient if I somehow could grab the group the particles are in. Edited December 9, 2014 by Phlok Quote Link to comment Share on other sites More sharing options...
edward Posted December 10, 2014 Share Posted December 10, 2014 Doesn't it obey the pscale attribute? If not, you can also try using VDB From Particle Fluid. Quote Link to comment Share on other sites More sharing options...
pbarua Posted December 12, 2014 Share Posted December 12, 2014 Append an AttribWrangle or PointWrangle before VDBfromparticles or VDBFromParticleFluid to vary pscale on groups. Then use this code: if(inpointgroup(0, "leaders", @ptnum)) @pscale = 0.05; // set pscale value if(inpointgroup(0, "trail", @ptnum)) //use your own group @pscale = 0.02; // and so on......... else @pscale *= 1; Quote Link to comment Share on other sites More sharing options...
pbarua Posted December 12, 2014 Share Posted December 12, 2014 Replace leaders and trail by your groups. And change pscale value whatever works for you. And if you have more group just keep on adding lines. Quote Link to comment Share on other sites More sharing options...
