Fractured Packed Animated object
segamega
Hello !
I have an alembic file with animated needles and first they should behave like an alembic file and then they should fall.
I use RBD fractured packed object, i made an active attribute for them and set it = 0, then i use sop solver to make this attribute = 1 when needles go through the box, but the problem is that needles dont get position from the alembic file when simulate and just stay at the 1st frame when active=0.
 How i can use position from alembic when they are passive using RBD fractured packed ?
Thank you.
Sorry for my english = )
Edited by segamega
