magneto Posted December 19, 2014 Share Posted December 19, 2014 Hi, Shouldn't this be a float type? I see for example the default uniform volume shader uses float for opacity but has to output to vector Of. Is this normal? Don't know how to visualize a vector opacity in practice. Thanks Quote Link to comment Share on other sites More sharing options...
rayman Posted December 19, 2014 Share Posted December 19, 2014 Isn`t this supposed to mean that opacity has color? 1 Quote Link to comment Share on other sites More sharing options...
magneto Posted December 19, 2014 Author Share Posted December 19, 2014 In this case how is a color opacity interpreted? By grayscale or luminance? Also the same can easily be achieved by using the surface color and then multiply with float opacity, right? So I thought having colors at both places is confusing. But I am not an expert Shading TD like Symek Quote Link to comment Share on other sites More sharing options...
Georgie Posted December 22, 2014 Share Posted December 22, 2014 (edited) https://www.sidefx.com/docs/houdini13.0/vex/contexts/shading_contexts Click the Opacity vs Alpha link. Explains it pretty good. Got to admit it was a really cool question. I never actually thought about that so first thing I did was fire up Houdini and play with a couple of clay shaders on a box and a sphere. Results were really weird and could figure out why 'till I found that info. Cheers and thanks for the good question. Of vectorThe final opacity for the surface. A value of {1,1,0} will be opaque in red/green, but let through blue light from behind. Seeopacity vs. alpha. Edited December 22, 2014 by Georgie 1 Quote Link to comment Share on other sites More sharing options...
fathom Posted December 23, 2014 Share Posted December 23, 2014 figure that color represented as RGB is really just 3 floats. RGB opacity just means 3 different opacity settings for each component being calculated. if you think of the RGB components being computed separately, it might make more sense conceptually. 1 Quote Link to comment Share on other sites More sharing options...
