Q about hard constraint
KiLa
Hi!
How does the constraint_type, condof and condir attributes work?
Im trying to create a hinge using hard constraint...so im setting the constraint type to all (to block the falling and to control the rotation), condof to 2 (to restrict the rotation to only 1 axis) and condir to 0 1 0... and my 'door' is falling.
Do i have to use two constrains? One to stop the falling, and another to control the rotation?
Attached file contains the scene.
Cheers
-k
ps: Using Houdini 13.0.447
constraint.hipnc
I could do that, but i was just trying to do it with Hard constraint :)
They say in the documentation thaty you could use 'position', 'rotation' or 'all' in the constraint_type attribute, but it seems that the hard constraint supports only position OR rotation. I haven't found a documentation which states the types that are supported in each constraint.
-k
