rbd key active question..
arifakca
hi,
i have a very basic setup here. a torus is just breaking. but if you look close the frames between  49 and 59 , you'll see fracturing parts is like child of main torus object.(look likes there is a child/parent relationships) after frame 59 parts moves normal. strange movement happening in those frames. any idea how to solve this?
thank you.
untitled.hipnc
the pieces that come off seem to get the inherent velocity of the main torus
one cheap trick to try is to increase the substep on the dopnetwork to 2
this will reduce the parented feel to some extend as there will be more substeps for dops to calculate  :)
giving u more break ups
Edited by newbee
