Problem with Displacement and Unified Noise
goafreak
Just a simple test (see attached hip file): A unified noise is driving displacement and color (no uv's, position is in object space).
The problem is, that the displacement and the color values do not match (see picture, the red color should be only the highest areas). The problem doesn't occur when using UV's for the position, but I want to use the position in object space.
What am I doing wrong? Any help would be appreciated!
Greetings,
Chris
problem.hip
post-11735-0-25293900-1420040012_thumb.j
