pop streams logic?
cgcris
Hi guys,
Attempting to do something with particles in H13, but I am struggling a bit with the logic of streams.
In the attached example you will see I create a second stream, and change the color of a percentage of particles.
What doesn't make a lot of sense to me is if I now then add a force to stream 01, it affects both streams. Even if I specify
on the force to only affect stream 01.
Can somebody explain me why this is?
Thanks,
Cris
pop_logic.hipnc
Not sure about your question.
Looking at your file you are applying a popforce to stream_grid_object1_source, which contains all of your particles (middle click and compare the number of points to the number in that group)
If you only want to affect popstream1 (the stream you separated), you need to change the popforce position after the merge, or on the 2nd branch and choose the correct group.
There is a simple example file you can load from the popstream Houdini help that separates streams based on position, colour them, and apply different forces.
