Problem with wire constraints
segamega
Hello !
I wanted to pull object by the wire, i found the way to do this, but now i need to animate wire or constraint wire to animated object, i did some tests and for small objects its (standard pin and glue constraints) work fine but if im trying to use it in a real scene with big objects: dymamic wire doesnt move after constrainted point.
I attach the file as refference. Its a big objeects now and if u will make them small everything will work fine. I hope that u know solution for this thing. Thank you.
test_constraint.hipnc
