7ofDiamonds Posted January 22, 2015 Share Posted January 22, 2015 I would like to texture a number of playing cards that are fanned out using the copy SOP. From there, how can I individually select each card and texture them with individual card textures? Thanks! Quote Link to comment Share on other sites More sharing options...
Fenolis Posted January 23, 2015 Share Posted January 23, 2015 In the Copy SOP, turn on "Create Output Groups" (the default naming prefix is fine). This will put each card into it's own copyGroup, which you can then call out in a material SOP to texture accordingly. I recommend checking/creating UVs before the copy, if you haven't already. Hope this helps! 1 Quote Link to comment Share on other sites More sharing options...
7ofDiamonds Posted January 28, 2015 Author Share Posted January 28, 2015 In the Copy SOP, turn on "Create Output Groups" (the default naming prefix is fine). This will put each card into it's own copyGroup, which you can then call out in a material SOP to texture accordingly. I recommend checking/creating UVs before the copy, if you haven't already. Hope this helps! Sorry for the late reply, I only had a chance to work on this yesterday and this worked. Very helpful, thanks! Quote Link to comment Share on other sites More sharing options...
