Fake Pilot Posted January 23, 2015 Share Posted January 23, 2015 Hello, I was wondering. What is the general workflow for say ... example: Connect an object to a COPY node, let the template be drawn up, say from a Curve and an animated Carve SOP. How would it be possible that each copy object scales up from zero animated, when the carve reaches a new point? Say, I would like to control the easing of the scaling of these objects as they appear. Can each copy have their own timeline that you can trigger when an attribute equals 1, true or false thing? Quote Link to comment Share on other sites More sharing options...
iamyog Posted January 23, 2015 Share Posted January 23, 2015 if you sort the points so the first created will always be number 0 you can then lay down a solverSOP and inside create a pointWrangler with this VEX code : @startframe = point(@OpInput2, "startframe", @ptnum); i@trigger = point(@OpInput2, "trigger", @ptnum); //trigger to store the startframe only once i@previous = point(@OpInput2, "total", 0); //previous number of points i@total = @numpt; //number of points in the line if (@numpt > @previous) { // We want to store the startframe on the "totalNumberOfPoints - 1" point // since number start from 0 we want to store on "totalNumberOfPoint - 2" : @numpt-2 float trig = point(@OpInput2, "trigger", @numpt-2); if (trig == 0) { setpointattrib(geoself(), "startframe", @numpt-2, @Frame, "set"); setpointattrib(geoself(), "trigger", @numpt-2, 1, "set"); } } Make sure to connect Input1 as the first input and prevFrame as the second. This code will store the frame at which the point had been discovered by the carveSOP in the attribute "startframe" you can now subtract it from the current frame and fit/clamp the result to drive your growing animation. Quote Link to comment Share on other sites More sharing options...
Fake Pilot Posted January 23, 2015 Author Share Posted January 23, 2015 (edited) Thank you iamyog! :-) But that is a bit too complex for what I was seeking. I have figured out a solution now. Just had to sit down and write it out in text first (and after hours of not thinking right). Like this: 192 trees are to be animated out over a course of 650 frames. Every tree have an animation that takes 20 frames each. With the help of a TimeWarp and a Copy SOP, I just have to figure out when they should start and stop and stamp it, making each unique with the $PT's of the copy template. start $RFEND/$NPT*$PT stop $RFEND/$NPT*($PT+20) Edited March 4, 2016 by Fake Pilot Quote Link to comment Share on other sites More sharing options...
Emi Ochoa Posted February 12, 2015 Share Posted February 12, 2015 EXELENT! Quote Link to comment Share on other sites More sharing options...
