POP regular particle emission
I'm confused how to set the pop source If I want to emit a particle at exactly each 100 ms.
I use a source and set its birth parameters to the following.
impulse Activation/count set to 0
Constant activation 1
Constant birthrate 10
So then I have a random spawing of 10 points within a second.
By switching off the probabilistic emission I was hoping to get a regular point emission. But instead I see nothing?
I saw that in the popsource digital asset when probabilistic emission is set to of then the popsource/sopsolver/attribwrangle1newpoint parameter is set to 0. hence no emission. So I could fix my problem by changing the popsource Digital asset. But I have a strong feeling this is not the right approach I'm taking here. :)
