2D aim constraint like behavior (orientation with quaternions)
xukca
Hi, am not quite sure if this is the right place, but I am using mostly vex/vops for this exercise so I'll post here. I would like to do an aim constraint setup with the possibility to turn an axis off (to switch from 3D to 2D so to speak). In my proof of concept I am isolating the case, when I have already picked a locked of axis (should rotate around Y), so:
1) I calculate the vector between the target object and the rotationa pivot
2) I define a plane (more like a a vector) through the rotational pivot
3) I do a dot product between the both vectors
4) I jump into VOPs, feed the dot product into trigonometric functions VOP set to arc cosine -> feed to the angle of quaternion -> rotate quaternion -> update P.
So far so good, the oriented object behaves great in the space between 0 and PI  (180), which is the return of the arcus cosine function... Also, dot product returns a value between -1 and 1, which fits the 0 to PI paradigm. When I move the target object below the rotational pivot, I got flipped rotation, which is to be expected but very undesired.
I want to have full rotation tho, does anyone have an Idea what  I can improve/change/use to get the 0-360 rotation (without JUMPS between quadrants)? I feel kinda stuck, thank you in advance!
