export curves to maya?
I made a particle system and created curves from those particles with an add sop.
But for the next part of my project, I need to bring those growing/changing curves into Maya for someone else to work with.
I thought I got the alembic export working once before, but I can't seem to duplicate it.
and any feedback on a better/ more efficient system would be much appreciated :)
I still like using the old POP network, and this file is in H13.
wireTest.hiplc
Adding a clean SOP helped...
I guess alembic is weird about attributes.
Now one animating curve exports and the rest never show up.
I tried pre-rolling so that initially there are 3 curves,
and when I bring that into maya, there are only 3 curves,
some of which flicker to locations of where the other new curves should be.
I guess it makes sense that all the geometry should exist on the first frame,
I'm just going to have to find a way to make it work with what i'm doing,
like making it emit from a larger volume under my ground plane all on the first frame
so I get variation in collision time
and just deleting the CVs in maya after the fact or something?
