RBD Constraint is not permanently deleting?
A. Morales
Noticed this while testing out some rbd in h14, I'm fairly certain this was not the case in h13 but I'm noticing my glue constraints are researching points post breaking and then reconnecting mid sim, I've attached my scene and obj below
No idea whats causing it, was messing with search radius , etc, I figure maybe a more permanent mainly solution to slap a solver in the sopsolver to save data of the previous frame, but again this is doing it on default shelf tool shortcuts.
Any idea?
Watch_Tower.hipncFetching info...
Watch_Tower.obj.zipFetching info...
I don't have the time to open your files, but it seems that you are talking about known problem with H14 default Override with SOP expression in Constraint Network node. If you delete it and set to 0 it should be ok. Or update your version - it is fixed.
  • Like 2
