j00ey Posted February 4, 2015 Share Posted February 4, 2015 Hi I have a few flipbook sequences of identical length, resolution etc that I want to just append one after the other and then write back out as one sequence. I've got the following expression in the filename field : $HIP/COPS/granularTest_v`padzero(2,ceil($F/75))`.`padzero(4,(($F-1)%75)+1)`.jpg I can see that it's evaluating correctly but what I'm seeing on screen is the first sequence looping. I've tried different post extend settings and setting the file range length differently but it doesn't work. I will do this manually for now but it would be very useful in future to be able to do this if anyone knows how... Thanks in advance Quote Link to comment Share on other sites More sharing options...
kungFu Posted April 29, 2016 Share Posted April 29, 2016 It doesn't seem to be a lot of work manually. Bring each file into COPs, put a shift node on each stream, set it to "shift start to shift value", then plug all of them into into a sequence node. Is this what you are doing and want to find an alternative to? js Quote Link to comment Share on other sites More sharing options...
