How do you name an attribute refering to an op: in Wrangle/VEX
abvfx
I have probably butchered the title so to make it clearer how do you use the hscript fuction op: in a wrangle sop (attrib or point).
Cant find anything on the topic.
I want to create an attribute and name it based on the file name within a filesop. I have come to think that the hscript op:`` is the way to go about it.
cheers
Edited by abvfx
cheers
Only way I can think of is to create a file spare parameter in your wrangle and place hscript expression there.
Cheers
I'm trying to figure out how that will work.
Maybe i should use one of the regular attribute sops and create the attribute there using the hscript op: for the name. Then access that attribute in the wrangle, i just would love to be able to do it in one.
edit:// now i just have to figure out doing it there :D
Edited by abvfx
