HeaderAche
Hi all,
We just installed the HDK here at work, and naturally, the first thing I did was try to compile one of the examples.... and it failed :(
The problem was easy to fix, and it's specific to using multiple compilers, but I just thought I'd mention it in case someone else runs into it.
Our license server (where the HDK was installed) is RedHat7.3 with gcc 2.96, and our workstations (where I do my development) are SuSE9.1 with gcc 3.3.3 -- much has changed between those two versions of gcc. Now; I don't know if hdkinstall has the smarts to expand a different set of headers for each Linux flavour (haven't tried since the hfs7.0.185 we downloaded had to be the one for RH7.3), but it means that I have to live (for now) in an environment with mixed compilers/OSs. (blame it on JC! :P)
What failed was the class UT_OStrStream in the header UT/UT_NTStreamUtil.h. And the reason for the failure is that this class inherits from std::strstream, which is deprecated (!) and so not visible in the standard include paths for gcc3. Problem #1 is that the old strstream cannot be blindly replaced with the new stringstream (from the header <sstream>) -- not only do they work differently, but the constructors have different signatures. And problem #2 is that none of the calls to the parent constructors are qualified with the std:: namespace (ok for gcc2.X, not ok for gcc3.X).
My quick workaround was to change lines 34 and 35 (in UT/UT_NTStreamUtil.h), which read:
#else
    include &lt;strstream.h&gt;
to:
#elif defined(GCC3)
    #include &lt;backward/strstream&gt;
    using std::ostrstream;
#else
    #include &lt;strstream.h&gt;
Another bit that gcc3.X couldn't grok was lne 171 in the file UT/UT_CPIO.h, which reads "istream *myis;", and should read "std::istream *myis;". At least those are the ones I've found so far...
....OK. Now I can start playing with my new toy!... "Hello World" here we come! :D
Cheers!
P.S: @Edward: Maybe the HDK should include a frozen version of <strstream>, since I think those backward-compatibility headers may disappear altogether for gcc4.0 (?)
... actually, wouldn't you run into problems with compiling your HDK stuff in gcc 3.3.3 and then telling a Houdini which was compiled with gcc 2.96 to load it?
13737[/snapback]
Hey Edward,
No, I don't run into problems because I'm building for a RH9 installation. So, with the fixes I mentioned in the post, all sample dso's compile and load just fine in our SuSE9.1 machines (which have a RH9 Houdini installation). For the license server machine and the other ones running RH7.3 (a RH7.3 Houdini installation, and gcc2.96) I have to do a separate compilation, for which I can use the original headers unchanged.
Our problem is/was that hdkinstall insists on installing only on the machine serving the licenses (RH7.3/gcc2.96 in our case), and we couldn't get it to install in any of the other ones. So I was stuck trying to compile in a gcc3 environment, using headers targeted at a gcc2.96 installation, wich worked fine for the RH7.3 machines, but failed for the SuSE9.1 machines...
As it turns out though, JC dug a little deeper and, a little after posting that message, we found out that hdkinstall was simply not working as intended: it is supposed to be able to install in any machine. So it's a bug in the end. I believe someone's looking into it.
Cheers!
  • 2 years later...
Heya,
It seems like this is still an issue? Is it 2007 already? :-)
I know they're mostly WARNINGS, not ERRORS, but I thought I'd raise the topic..
I'm using a RH installation (2.6.11-1.1369_FC4smp) with g++ version 4.0.0 and Houdini 8.1.655.
While trying to compile the RealFlow Exporter SOP from sources (ie. the "SOP: Realflow" inside Houdini.RealFlow_v1.0.0.src.tar.gz) from sourceforge (http://sourceforge.net/projects/odforceplugins) I'm getting an error on UT_NTStreamUtil.h
 $ make
/usr/bin/g++ -DVERSION=\"8.1.655\" -DDLLEXPORT="" -DMAKING_DSO -D_GNU_SOURCE -DLINUX -DI386 -DSESI_LITTLE_ENDIAN -DENABLE_THREADS -DUSE_PTHREADS -DOFSTREAM_PERMISSIONS=", 0666" -DGCC4 -I/X/tools/binlinux/sesi/hfs8.1.655/toolkit/include -Wall -W -Wno-parentheses -Wno-sign-compare -Wno-reorder -Wno-uninitialized -Wunused -O2 SOP_RF_Export.C
In file included from /usr/lib/gcc/i386-redhat-linux/4.0.0/../../../../include/c++/4.0.0/backward/iostream.h:31,
from /X/tools/binlinux/sesi/hfs8.1.655/toolkit/include/SYS/fpreal16.h:93,
from /X/tools/binlinux/sesi/hfs8.1.655/toolkit/include/SYS/SYS_Types.h:65,
from /X/tools/binlinux/sesi/hfs8.1.655/toolkit/include/UT/UT_EnvControl.h:29,
from SOP_RF_Export.C:31:
/usr/lib/gcc/i386-redhat-linux/4.0.0/../../../../include/c++/4.0.0/backward/backward_warning.h:32:2: warning: #warning This file includes at least one deprecated or antiquated header. Please consider using one of the 32 headers found in section 17.4.1.2 of the C++ standard. Examples include substituting the <X> header for the <X.h> header for C++ includes, or <iostream> instead of the deprecated header <iostream.h>. To disable this warning use -Wno-deprecated.
/X/tools/binlinux/sesi/hfs8.1.655/toolkit/include/OP/OP_Node.h:1134: warning: unused parameter
