argilop Posted February 10, 2015 Share Posted February 10, 2015 Hi there, I managed to birth particles as rbd objects through a SOP_SOLVER but I am facing problem when I want to scale the copied geometry based on the life time of the particles. Due to is not a conventional particle simulation I can not use $LIFE or $AGE. I would like to ask if someone has an idea of how to create an attribute which stores the birth time information and therefore scale the geometry based on that. Thanks Quote Link to comment Share on other sites More sharing options...
xray Posted February 12, 2015 Share Posted February 12, 2015 It would be best if you could attach an annotated example file showing the issue, but my first guess would be to use a point wrangle in your SOP solver to set some attribute with $TIME on particles in a group of "just born" particles. Quote Link to comment Share on other sites More sharing options...
