Pointattributes and Field Force DOP
tfreitag
 I think that field force vop is meant to be used more for rigid body simulations.  If you want a per particle force I would think you would use a pop vop and just lookup the vector from your field with volume sample from file..  or use a pop force and use vexpressions to modify per particle forces.
 -G
I tried also this expression: point("$OBJID/birds",  $OBJID(or $ID), "distdanceforce", )  But $ID doesnt work.
I have popsolver setup, so how can I acces my $ID?
I would be very happy about every help :)
