ispep Posted February 12, 2015 Share Posted February 12, 2015 (edited) So I know how to do this in 3DS MAX I'm just trying to get it working in houdini; using its built in comp I can generate a simple noise map but how do I reference this at sop level - this way I don't have to create the files beforehand and can have it procedurally generate the necessary amount of frames. I have plugged in a caustics file from that free generator and gotten this result, but its way too big and I can't find a way of tiling it. scratch that. as is usual I do find way of tiling it, by unticking cone angle for field of view. Sorry. edit; unfortunately it doesn't actually render so even if I did get my own procedurally generated images referenced they wouldn't show on the render. Can anyone help with that please? Edited February 12, 2015 by ispep Quote Link to comment Share on other sites More sharing options...
Guest tar Posted February 12, 2015 Share Posted February 12, 2015 Not sure why it's not working for you; check the attached. Caustics2.hip Quote Link to comment Share on other sites More sharing options...
ispep Posted February 13, 2015 Author Share Posted February 13, 2015 That seems to work for me, not sure why it wasn't working previously. Thanks a bunch, it's genuinely appreciated. Quote Link to comment Share on other sites More sharing options...
jkunz07 Posted February 14, 2015 Share Posted February 14, 2015 That's quite a nice caustic pattern pictured in your first post ispep, are you generating it in Houdini or elsewhere? Quote Link to comment Share on other sites More sharing options...
ispep Posted February 16, 2015 Author Share Posted February 16, 2015 That's from the generator; http://www.dualheights.se/caustics/ it has a free version. Quote Link to comment Share on other sites More sharing options...
