Juzwa Posted February 17, 2015 Share Posted February 17, 2015 Hi, How can I brake cone twist and hard constraints by overwriting the constraint's geometry each frame? I have set the constarints properly and then made sure that 'Overwrite with SOP' is set. But unfortunately only glue behaves as I want to. Other constraits does not break. They stay just like as starting point of the sim Quote Link to comment Share on other sites More sharing options...
Solitude Posted February 17, 2015 Share Posted February 17, 2015 You can use a sop solver to remove or add constraints to the geometry. The default sop solver has a node inside of it that brings in relationship geometry. Quote Link to comment Share on other sites More sharing options...
