Juzwa Posted February 23, 2015 Share Posted February 23, 2015 (edited) Hi, I've recently switched from max to houdini. So my thinking is a bit different. I have a setup to create: an exploding tyre. I have done a lot of bullet simulations so my thinking was: I can create a sim with constraints of this object exploding. However this would not be a soft object. But if I could Skin (like skin modifier in max or sth) the object with my sim the whole might behave softer. So.... Can I use a bullet solver data to drive another sim? I'm just guessing here, I don't know Houdini enough if this is a best approach to this example Edited February 23, 2015 by Juzwa Quote Link to comment Share on other sites More sharing options...
CiaranM Posted February 24, 2015 Share Posted February 24, 2015 You might try using the cloth capture/deform SOPs? Hi, I've recently switched from max to houdini. So my thinking is a bit different. I have a setup to create: an exploding tyre. I have done a lot of bullet simulations so my thinking was: I can create a sim with constraints of this object exploding. However this would not be a soft object. But if I could Skin (like skin modifier in max or sth) the object with my sim the whole might behave softer. So.... Can I use a bullet solver data to drive another sim? I'm just guessing here, I don't know Houdini enough if this is a best approach to this example Quote Link to comment Share on other sites More sharing options...
rayman Posted February 24, 2015 Share Posted February 24, 2015 You might try using the cloth capture/deform SOPs? Exactly! Combine it with sop solver and you have really nice framework to create bend/tear deformations. Quote Link to comment Share on other sites More sharing options...
