Pyro Heat Field vs Temperature
bandini
Silly question, but what is the difference between the heat field and temperature field? Temperature is measuring and tracking the temperature of the sim, feeding into buoyancy, but what is heat measuring and doing? Is heat dependent on fuel, or can a heat field exist without a fuel field?
Heat is a product of the burn field. Burn is generated each frame with something like.
if temperature > ignition temp
    burn = fuel * burnrate
Heat is then created with max(burn,heat) and advected.
In other words, heat is created at places with fuel and high temperature. Temperature may exist anywere.
  • Like 4
It's also easy to think about it as heat is fire and temperature is just the temperature of the voxels in the sim...
So usually you'll use heat as "where fire is" and you'll colour temperature by a ramp that is masked by heat to get your final fire output.
But that's more on the rendering side.
  • Like 2
