Juzwa Posted February 25, 2015 Share Posted February 25, 2015 (edited) Hi, I have an animated maya locator exported to allembic. In Houdini I checked 'Load Maya Locator' and after created some points around in VOPs to make sure the animation does load (so I could see it in the viewport). However I have no movement. 'Load Maya Locator' seem to does not do anything and I dont get any data Edited February 25, 2015 by Juzwa Quote Link to comment Share on other sites More sharing options...
Guest tar Posted February 25, 2015 Share Posted February 25, 2015 Here's an axis from Nuke, when exported as .abc, it becomes a Maya locator. The animation is coming in Houdini with 'Load Maya Locator' Nuke 9.04, H14.0.254 1MayaLocatorsNuke.abc.zip Quote Link to comment Share on other sites More sharing options...
Juzwa Posted February 25, 2015 Author Share Posted February 25, 2015 (edited) Your file loads ok, mine is empty (but loads fine in maya) https://dl.dropboxusercontent.com/u/22676624/exhaustionAnim.abc Edited February 25, 2015 by Juzwa Quote Link to comment Share on other sites More sharing options...
Guest tar Posted February 25, 2015 Share Posted February 25, 2015 Try setting Create Primitive For -> Transform Nodes. You should see movement in H14.0.254 Quote Link to comment Share on other sites More sharing options...
