arifakca Posted February 27, 2015 Share Posted February 27, 2015 hi, i succesfully accumulate Cd attribute via animated sphere on a grid. it basicly transfers and keeps color from sphere to grid. but if i animate grid via mountain sop or transform node , solver sop stops working. it allways shows first frame of animated geometry. is there any solution for animated object? scene file is H14 but same thing happens in h13. thnks. solverSOP.hipnc Quote Link to comment Share on other sites More sharing options...
sadhu Posted February 28, 2015 Share Posted February 28, 2015 (edited) 1.In Animated version/sop_solver sop, you are transferring the color on previous frame.This is allowing houdini to remember color info on the previous frame. 2. For position you need live geometry, input_1 node in sop solver. Take position data from this node and use it to set position for previous frame geometry. solverSOP_Solution.hipnc Edited February 28, 2015 by sadhu 2 1 Quote Link to comment Share on other sites More sharing options...
arifakca Posted February 28, 2015 Author Share Posted February 28, 2015 super cool thnks. Quote Link to comment Share on other sites More sharing options...
WLVL Posted November 2, 2015 Share Posted November 2, 2015 thank you sadhu! Quote Link to comment Share on other sites More sharing options...
