How is Emission calculated in Mantra Surface material?
magneto
I was looking at Mantra Surface material and was trying to find out how emission is implemented but it seems like it's not used inside the Surface Model subnet? It works when I turn it on though.
I used View Dependencies tool and it shows no dependencies or references for these parameters.
Any idea on how they influence the resulting shader and how they are implemented?
The parameters are referenced using /mantrasurface/surfaceModel/subinput_opacity This node is a reference to all the parameters but only some are exposed on that instance for cleanliness
​With Ce/Emission exporting it as a variable makes it available as a pass (AOV) as well as emissive
Emission illuminates objects is handled by making emission visible to secondary rays
