Snow Simulation with the new PBD solver
croleo
Hi everybody,
I'm DangVy Nguyen, i'm a FX Artist Junior.
Here is my demoreel:
I'm currently learning houdini for some month, i'm begin to play with the new sand solver. It's very cool and fast!
Actually, I do some test with the "Grain Solver" in Houdini 14.
I try to do the Snow Packing, and i have a problem with the snow, it through the ground.
I put the ground in the "Bullet Data" Concave instead of Convex. I put the sphere in "RBD Object", the collision with the ground is perfect but not for the snow....
I attached my scene, for you see it yourself.
Thanks for your help! :)
Well, I did 3 things ;
1. recreated your ground geometry from separate box primitves and set it to Convex Hull - Create Convex Hull per set of connected primitives on the Static Object DOP
2. used a box as a source for the particles since your geometry file was missing
3. ( try this first ) set the Merge DOP (the one merging the solvers) to Left Input affects Right Inputs -- it was set to mutual. I still don't understand how exactly that particular one works but anyway - the particles are not going through the ground anymore
I'd upload the file but I changed so many parameters to speed up the sim that you'd have to waste a lot of time tracking those
Ok, thanks.
I though also, it work for the simple ground, but for the complex ground, recreated separate box primtive for each tilt...it's tedious
I'm doing a test with the Snow Plow, i'll let the Convex Hull and it work...(it work too when the geometry is Concave)
Here is a preview
Edited by croleo
