Is there a way to stop a Foreach SOP?
I noticed Foreach SOP has a Stop Condition parameter but there is no example that I could find. For example can I stop it when a detail attribute has a certain value or when a group has no elements inside?
It mentions something about stamping but I don't know what I can stamp? Should I be stamping the each node inside?
one use  of stop condition that I know is to visualize output of each iteration. Write stamp(".","FORIDXVALUE",0)>$F in stop condition. If this value evaluates to zero it will continue not otherwise.  If you compare this with a detail attribute , it should work.
try detail("../foreach1/attribwrangle1","aa",0)>30 in stop condition.
Now value of "aa" is not going beyond 30.
I never used it this way before. Not sure if this is the solution or it will work in all the cases. Will do more tests once I get little free time.
  • 2 months later...
This example is working but you should prefix your attribute references in AttribWrangle with the right type, which in your case is i, so i@c, i@stop. I don't know if this could your issue in your other file but something to keep an eye on.
