VEX UI help
dszs
Hi guys,
             I am quite new in VEX and I faced some problems when doing the ui.
For now I have a pragma code that states
#pragma hint pccloudpath invisible
I understand that this makes it invisible so I cannot edit it on the parameter interface, but how do I make a toggle for this to appear when I want to give it my own input?
Any help is much appreciated!
- Darren
There is a built-in method to hide parameters from other parameter states when creating vex nodes from vex code.
Say you have a toggle parmeter called "toggle", then you can do this to hide a parameter called "parm" when toggle = 0:
#pragma hidewhen  parm { toggle == 0 }
