HQueue server, dropping jobs by ropOutput
I'm having troubles with jobs submitted by HQueue Simulation and ropOutputDriver.
What I mean is that when I send the job using other node as Output Driver (eg dopIO) the job is beeing sent and calculatd properly. But when I sent the job to be simulated on ropOutput the job is failing, and I get the message in the Command Output:
"No licenses could be found to run this application.
Please check for a valid license server host"
running on win7
Edited by Juzwa
