luc255 Posted March 27, 2015 Share Posted March 27, 2015 Hi everyone, I would like to know if you have any ideas how to create nice UVs between morphing shapes. Enclosed I have created two ways to do that, but with the first one, I have a strange frange between my UVs and with the second, it is a little bit blurred. Thank you for your future tips and tricks! Sylvain. PS: It's for my school short movie. fusion_uv.hipncFetching info... Quote Link to comment Share on other sites More sharing options...
luc255 Posted April 7, 2015 Author Share Posted April 7, 2015 Up... Currently, I am blocked in my school short movie.. Thanks. Quote Link to comment Share on other sites More sharing options...
mattak Posted April 9, 2015 Share Posted April 9, 2015 (edited) Hi Sylvain, This is a followup to your DM about the UV Texture to FLIP particle fluids mesh RnD on Vimeo. Firstly have a look and download Spev's hip file here: http://forums.odforce.net/topic/15866-melting-a-textured-object-with-flips/?p=97374 Dig through that to get a good understanding as it's a nice simple file. You can then swap out the geometry source with any VDB_to_poly shape (or fluidSource node in my case) you wish to use, adding point UVs in the same way. To fix the UV seam issues should they come up, add a polyExtrude. Here's the source geometry network I used for the end example in the video: Cheers, Matt Edited April 9, 2015 by mattak Quote Link to comment Share on other sites More sharing options...
luc255 Posted April 10, 2015 Author Share Posted April 10, 2015 Hi matt, Huge thanks for your complete answer ! But I guess there are several things I have misunderstanding, I always have my UV seam after your process. Enclosed there are some exemples. Best, Sylvain. uv_seam_matt.hipncFetching info... Quote Link to comment Share on other sites More sharing options...
