Morphing VDB shape and UV
luc255
Hi everyone,
I would like to know if you have any ideas how to create nice UVs between morphing shapes.
Enclosed I have created two ways to do that, but with the first one, I have a strange frange between my UVs and with the second, it is a little bit blurred.
Thank you for your future tips and tricks!
Sylvain.
PS: It's for my school short movie.
fusion_uv.hipnc
  • 2 weeks later...
Hi Sylvain, This is a followup to your DM about the UV Texture to FLIP particle fluids mesh RnD on Vimeo.
Firstly have a look and download Spev's hip file here:
http://forums.odforce.net/topic/15866-melting-a-textured-object-with-flips/?p=97374
Dig through that to get a good understanding as it's a nice simple file.
You can then swap out the geometry source with any VDB_to_poly shape (or fluidSource node in my case) you wish to use, adding point UVs in the same way.
To fix the UV seam issues should they come up, add a polyExtrude.
Here's the source geometry network I used for the end example in the video:
Cheers,
Matt
Edited by mattak
