Converting a matrix3 to euler
meshsmooth
In VOPS or VEX how do I Convert a matrix3 to a matrix 4... well what i really want to do is convert quaternion to Euler but this proves to be a non trivial affair. any ideas? it is being outputted to chops that is why the output is Euler.
14113[/snapback]
You might want to look at the cracktransform() function. Since you're also looking at quaternions, you might want to check out qconvert(), and quaternion().
In the Help browser, go to Vex > Vex language reference > The Runtime Function Library.
But here's one VOP method:
- Append Quaternion to Matrix3 VOP
- Append Matrix3 to Float VOP
- Append Float to Matrix VOP. Be careful to wire them with all the correctly matching names. Basically, all the inputs that contain the number 4 should be left unwired.
- Append Extract Transform VOP
This would make a handy custom VOP subnet I guess unless there's an easier way ...
