Volume sample within gasfieldvop
I'm using a gasfieldvop and would like to sample one of the simulation fields from an arbitrary P.
The obvious way is to use the volume sample or volume sample from file VOPs.
However, I'm not sure of the best way to access the desired field from the volume sample VOP.
My current working solution is to dopimport the desired field into a sopnet and put a pointer to that op into sample volume from file. Works OK, but this feels pretty convoluted.
So, is the a more straightforwad way to directly sample any field within gas field VOP?
Thanks.
Ciaran,
 You can use the Paramater VOP for this. You'll need two parameter VOPs. Both set to the same same name and type as the field you are looking to manipulate.
The first parameter VOP can be used to read in the field, then set the second to 'Export Always', and this will return your output back to the sim.
cheers,
-j
thanks for taking a look.
Unfortunately, as far as I understand, using parameter or bind VOPs will return the value of the named field at the current voxel position. I'm not manipulating a field but, I'm sampling a different field at some arbitrary, far away position. Unless I'm mistaken, I should be using volume sample VOPs? At this point I don't know of a way to directly reference a DOP field in those VOPs...
If I find a moment I'll throw together an example.
Edited by CiaranM
Haha, yeah this is a good one :)
It'd be nice if the Gas Field VOP had the same Inputs tab as the Geometry DOP, that would solve this. I don't know of a straightforward way to do it as things currently stand, but you could create a temporary vector field, use one Gas Field VOP to store a noised Position in that field, use Gas Lookup to pull the values from your desired field at the displaced position and store in another temporary field, then perform any further operations in a second Gas Field VOP. But, indeed, this would be wack.
gaslookup.hip
Edited by tjeeds
  • 4 months later...
