vitek Posted April 5, 2015 Share Posted April 5, 2015 Hi guys, Do you know any simple way how to transfer point attributes onto particles within POP net? There is an AttribTransfer node in old POP net, however I can't find anything like that in new POP net. I've found there is the node which can transfer just volume attributes but I don't want to convert my mesh to volume. Any ideas? Thanks, V. Quote Link to comment Share on other sites More sharing options...
Rio.Dominia Posted April 7, 2015 Share Posted April 7, 2015 U can post ur file. And we can know more about the details. Quote Link to comment Share on other sites More sharing options...
vitek Posted April 7, 2015 Author Share Posted April 7, 2015 Hi Rio, thanks for your answer. I'm trying to do something like attribtransfer in the end of this tutorial, so I don't really have a file - I'm rather interested if there is still simple way of transfering the attributes from points to points this way I'm fairly new to this stuff, so any advice would be greatly appreciated! https://www.sidefx.com/index.php?option=com_content&task=view&id=2186&Itemid=361 Many thanks! Quote Link to comment Share on other sites More sharing options...
pbarua Posted April 8, 2015 Share Posted April 8, 2015 You can use "popwrangle" with point() VEXpression function for that. Or sopsolver > dive inside > objectmerge geometry to transfer attribute from > attribtransfer Play with "Distance Threshold". Quote Link to comment Share on other sites More sharing options...
Rio.Dominia Posted April 9, 2015 Share Posted April 9, 2015 Hi Rio, thanks for your answer. I'm trying to do something like attribtransfer in the end of this tutorial, so I don't really have a file - I'm rather interested if there is still simple way of transfering the attributes from points to points this way I'm fairly new to this stuff, so any advice would be greatly appreciated! https://www.sidefx.com/index.php?option=com_content&task=view&id=2186&Itemid=361 Many thanks! Will in the sop solver U can use object merge to get the attributes' object . and use the attributetransfor node to transfor the attribute to the partilecs . cheers Quote Link to comment Share on other sites More sharing options...
vitek Posted April 10, 2015 Author Share Posted April 10, 2015 guys, thank you very much, I'll have a look into that! Quote Link to comment Share on other sites More sharing options...
