SBD Spring Constrain Broken in H14?
Hi guys,
After lot of trial , it looks that sbd spring constrain is broken.
I have also download and test those 2 scenes :
http://forums.odforce.net/topic/17223-spring-constrain-for-every-point-inside-groups-for-dynamic-bridge/?hl=%2Bspring+%2Bconstrain
http://forums.odforce.net/topic/10309-physics-spring-constrain-without-collisions/?hl=%2Bspring+%2Bconstrain
and i get the same behavior :
- the spring connections looks to work as i can see the red connections
- but it has no effects
- the force and length limit doesn't work also.
Could you please confirm that , this time the problem is not coming from the guy behind the keyboard ? :)
Here is a trivial exemple of the problem :
spring_constrain_bug.hipnc
Edited by sebkaine
