nguyenvuducthuy Posted April 13, 2015 Share Posted April 13, 2015 hi there, when i do some cloth simulation in houdini 14, and when collision intersect each other i have that problem, in houdini 12 it good but in houdini 14 it dont work, so what i missing here?? Quote Link to comment Share on other sites More sharing options...
zoki Posted April 13, 2015 Share Posted April 13, 2015 probably your collision mesh /table is too sparse try setting collision detection to edges on surface type Quote Link to comment Share on other sites More sharing options...
nguyenvuducthuy Posted April 13, 2015 Author Share Posted April 13, 2015 in houdini 14, when i check on in cloth object visualization> penertration i dont see anything but it work in houdini 12 i see a red color an collision temporary disable in this region, so why it not happen in hou 14, can u help?? thank you, Quote Link to comment Share on other sites More sharing options...
edward Posted April 14, 2015 Share Posted April 14, 2015 It might be a bug accidentally introduced. But you should first try to recreate the cloth object in H14 and note that the units do not match previous Houdini versions. So some values between older Houdini versions might need to differ by 1/10th or 10x, 1/100th or 100x, etc. Read the helpcard on the cloth object. Quote Link to comment Share on other sites More sharing options...
nguyenvuducthuy Posted April 14, 2015 Author Share Posted April 14, 2015 thank for replies, but still no luck, i can not find what wrong with it Quote Link to comment Share on other sites More sharing options...
