syzmatrix Posted April 20, 2015 Share Posted April 20, 2015 Hello, I am trying to making some building destruction. And I need a lot of "blast" operation to delete meshes. When I select a mesh, some faces are selected but not the entire mesh. So how can I select a whole mesh at once. Thank you guys in advance! Quote Link to comment Share on other sites More sharing options...
woodenduck Posted April 20, 2015 Share Posted April 20, 2015 You need the 0 hotkey. In the viewport, press 's' to activate selection mode, then press 0 to toggle 'select connected geometry'. This will select all connected points/edges/primitives/vertices depending on what selection mode you are in. Quote Link to comment Share on other sites More sharing options...
pbarua Posted April 20, 2015 Share Posted April 20, 2015 And to add to current selection: press enter on viewport > back-tick(`) then modify selection and press enter again. Quote Link to comment Share on other sites More sharing options...
