spring custom velocity , how to?
bestxhh
Hi guys
I made a break for a text now
Want to use spring to do the effect of node.
But the spring node itself provides no wind is a random value vector
I use VOP to each point set up a random initial velocity
But now the initial velocity of each point are not the same in motion at sixes and sevens this is not what I want
Now, how should I give all the pieces of the settings on the same vector instead of a single point
There are more random wind field, SOP has a better spring for nodes to use?
Thank you:)
