goafreak Posted April 25, 2015 Share Posted April 25, 2015 Hi, I'm trying to access an attribute inside a popnet to set for example the impulse rate of the emission based on that attribute. It doesn't work though and I want to understand why... The attached demo scene does the following: - Create a speed attribute (speed) based on the length of the velocity vector of the geo points. - Then this attribute is promoted to a primitive attribute (I guess that's needed, because accessing a point attribute doesn't make sense in the next step) - Now I should be able to use that attribute with $SPEED inside the popnetwork to control the impulse rate. Why is that not working? Btw, I know how to do this effect in an alternative way, so this is more a general question. I hate unsolved problems Any help would be appreciated! Cheers, Chris attrib_to_pop3.hipnc Quote Link to comment Share on other sites More sharing options...
