dszs Posted May 5, 2015 Share Posted May 5, 2015 Hi guys, Once again, I need your help on cloth simulations. Like the image below, there is a penetration that I can't solve. I have played around with cloth settings, as well as the accuracy tab and substeps in finite element solver. But still the penetration exist. Do you guys know any solution to this problem? Quote Link to comment Share on other sites More sharing options...
Georgie Posted May 5, 2015 Share Posted May 5, 2015 Your geometry is a static object, yes ? Have you tried playing with the parameters on the Collision tab ? Also try increasing the Collision Passes on the FEM Solver Altho to be honest that looks really weird. It would be great if you could upload a file for people to check out. Quote Link to comment Share on other sites More sharing options...
dszs Posted May 6, 2015 Author Share Posted May 6, 2015 The model is animated. I wanted to upload a flipbook but somehow the uploader here doesn't allow me to. I will try to do up a hip and post it up here!! Quote Link to comment Share on other sites More sharing options...
Fenolis Posted May 6, 2015 Share Posted May 6, 2015 Looks like your polygon count doesn't remain consistent throughout the duration of the simulation.Try appending a Font SOP with the expression: `nprims(../node_you_want_to_check)` and run a Flipbook to see if the polygon count changes over the course of your cloth simulation. Hope this helps! Quote Link to comment Share on other sites More sharing options...
dszs Posted May 6, 2015 Author Share Posted May 6, 2015 Hi Fenolis, Thanks for your reply! Tested it and yup there is a change in poly count. Guess I will have ask the modeler fix the model :\ Thanks for the help!! Quote Link to comment Share on other sites More sharing options...
