ino Posted May 5, 2015 Share Posted May 5, 2015 how can i get a strong bounce whit fem ? there is this damping ratio i would expect an object to bounce for ever when i set this to 0 or where else do i lose energy how can i let a ball bounce for ewer whit fem thx Quote Link to comment Share on other sites More sharing options...
rafaelfs Posted May 5, 2015 Share Posted May 5, 2015 I'm not sure if it'll bounce forever, but have you checked the bounce value on the colliding objects? I think ground plane, for example, has default bounce of 0.5, which causes it to push objects back with half the force it receives. Cheers Quote Link to comment Share on other sites More sharing options...
ino Posted May 5, 2015 Author Share Posted May 5, 2015 well they more i play whit it it seam that i getting not bounce at all the only way to get it look like it would bounce is to set the target stiffness or damping which isnt a real bounce but sort of a transform or morph can some one confirm that ? is there some way around ? Quote Link to comment Share on other sites More sharing options...
ino Posted May 6, 2015 Author Share Posted May 6, 2015 the effect i am looking for is more or less what you rafaelfs achieved in your "jelly" render example is that as the shelf tool sets up a cloth and just the parameters tweaked or are there additional nodes if you could share the hip file of this render it would by awesome cheers Quote Link to comment Share on other sites More sharing options...
