Is there a DOP level Wrangle node in H14?
magneto
I know there are a few wrangle nodes at the DOP level but I mean something that can do what most Gas DOP nodes do? For example we have Gas Match Field DOP. and Gas Calculate DOP. Can we do these in VEX?
To me it seems like most DOPs are what VOPs are, and seem unnecessary at the DOP level if you can just use VEX code instead.
So can one write smoke solver in DOPs only using VEX? I don't know if doing this in SOPs is better or even make sense? I assume if you do it in SOPs, you will lose all the other stuff in DOPs?
I know these Gas nodes have OpenCL support which Wrangle nodes don't but apart from that would it not make simulation objects and solvers a lot simpler if they could be expressed purely in code?
