HOM to expand/condense point lists "8 10-13 2" <-> &#3
Are there any convenience functions in the python HOM to expand/condense "group" type lists of geometry? Or do I have to write my own python functions to handle this?
For example I want to change:
1 5 8-11 13  into  1 5 8 9 10 11 13
or the other way around.
Also I'd like to be able to clean up:
1-10 5-12 20  into  1-12 20
Before I deal with it myself I figured there might be something in HOM that helps since it's such a standard way of listing geometry in Houdini.
Thanks!
Edited by cruiserandmax
If you have the actual geometry, then for expanding, you can make use of hou.Geometry's globPoints(), globPrims(), etc. that returns you back a tuple. So untested code would be something like:
" ".join([str(pt.number()) for pt in geo.globPoints("1 5 8-11 13")])
I'm not sure if there's an easy one liner for condensing though.
