Custom Lens Shader: What is the length of I?
jonp
Greetings,
I've mostly implemented a fisheye lens shader in VEX which traces the rays where I want them, etc...  but I've noticed that the standard surface shader and texture derivatives are scaled by the length of I.
So does anyone know what exactly this should be set to?
Jon
Edited by jonp
I asked the wrong question...
It was a conditional in the lens shader that confused the derivative calculation... tests that set I to zero at the beginning of the render will set the derivatives incorrectly.  I think this may be fixed in a newer build (14.0.258).
