Motion Vectors problem with Arnold
Hi
I'm trying to render a motion vector pass with Arnold.
Everything is fine as long as I try to have a Transformation Blur, but as soon as I try to get some Deformation Blur, no blur is detected.  My Arnold Shader Network look like this :
Motion Vector ---> OUT_Material
Geometry Velocity Blur is activated on my geometry.
Specs:
CentOS release 6.6 final
Houdini 14.0.201.13
Arnold 1.3.0
I tried different ways to deform a torus.  xform is working.  Moving points with a Point SOP don't.  Animating a Mountain SOP works some times.
Any idea how to set that?
Thanks
Maxime
Oh Yeah!
I'm new to Arnold.  Didn't add the Arnold Properties to my geometry node.  Now it seems to work.  Added a couple Trail SOP with compute velocity, and now it's fine.  But is there a way to compute those motion vectors without blurring the render.  Actually, my motion vector pass is an AOV, and as soon as I try to remove the blur from the render, my Motion Vector pass stop working properly.  I tried to set the shutter as explained in the Motion Vector documentation :
https://support.solidangle.com/display/AFHUG/Motion+Vector
But it seems I can't obtain the correct Motion vector pass without blurring the render.
Thanks
Maxime
  • 2 weeks later...
Hi Michael
Yes, the Arnold ROP node in Houdini have an option to turn off Motion Blur, but when I turned it off, motion blur AND motion vectors were turned off.  The trick was to set the shutter directly on the Arnold properties on the geometry node.
Thanks
Maxime
