group selection
vijaykumar
Hi.. i used group node(bounding volume points only) to select my fragments using an object(converted into vdb). after the points get selected  i want to delete the fragments of connected points. if i delete it the points gets deleted... also tried convert from points to primitives in group sop and tried deleting using delete sop.. but the primitives only gets deleted. not the whole fragment..help me out.. thanks in advance :)
