yjcnbnbnb200 Posted May 19, 2015 Share Posted May 19, 2015 There is an output node in dop network in H14, but I found it seldom work, often nothing happen after I pree the render button on the panel, any tips? Quote Link to comment Share on other sites More sharing options...
Guest tar Posted May 19, 2015 Share Posted May 19, 2015 (edited) It should be saving the cache out so you can then check 'Playback Simulation' on the Dop Network at Scene level. The node will then say playing back so so file, and in the Dop Network it will have 'Network in Playback Mode' in red. Edited May 19, 2015 by tar Quote Link to comment Share on other sites More sharing options...
yjcnbnbnb200 Posted May 19, 2015 Author Share Posted May 19, 2015 It should be saving the cache out so you can then check 'Playback Simulation' on the Dop Network at Scene level. The node will then say playing back so so file, and in the Dop Network it will have 'Network in Playback Mode' in red. Thanks, I know what you mean, my bad, the button is [save to Disk], sometimes it work and start to save the cache, but most of the time it is only a button... Quote Link to comment Share on other sites More sharing options...
Guest tar Posted May 19, 2015 Share Posted May 19, 2015 Do you have a test file to upload, please. We can then test it. thanks! Quote Link to comment Share on other sites More sharing options...
yjcnbnbnb200 Posted May 19, 2015 Author Share Posted May 19, 2015 (edited) Do you have a test file to upload, please. We can then test it. thanks! Here it is, just click the Save to Disk button in output node. dop_output_save_to_disk_TEST.hipnc Edited May 19, 2015 by yjcnbnbnb200 Quote Link to comment Share on other sites More sharing options...
Guest tar Posted May 19, 2015 Share Posted May 19, 2015 It appears to be not working as Apprentice doesn't allow .sim files to be written out. Quote Link to comment Share on other sites More sharing options...
