Controlling speed of an object
keltuzar
I am trying to make small simulation where in an object follows a path .
as u can see, I have made a box that is connected to the path.....
I am trying to evaluate the speed of the box over the curve.... wherein as it goes down it accelerates and when it goes up it looses velocity.
Wht I have come up so far is using CHOPs, and using the slope chop. But I dont seem to get a good result from it.
Please help me out...
thanks in advance
Have you tried a TrailSOP set to "compute velocity"? Bring up a geometry spreadsheet and check the "v" (velocity) values. If you're doing the animation on a path at the object level, Object Merge SOP your cube into a separate object, make sure that Transform Object is set to ".", and append the TrailSOP to that...or maybe you've already tried this. :)
stu
