How to use command line to render dop I/O and file cache nodes?
no idea what mread does, I use hbatch then I navigate to the file I want to render
hbatch myFile_001.hip
cd /out
ls (to list the nodes)
render myRopNetwork or w/e the node name is
you can also type ' help render ' to get a list of flags
  Quote
'mread' is used to read .hip file in shell. It's old command from PRISMS. All commands start with 'm' are inherited from PRISMS. To write from shell there is 'mwrite'.
If didn't give file to 'hbatch' to open then you can use 'mread' to read .hip in current hbatch session.
In Terminal type:
hbatch
// It will load installed version of Houdini and prompt to enter commands
hbatch Version 13.0.376 (Compiled on 04/08/14) // or whatever version you are on
/ -> mread /path/to/hip/file
/ -> cd /path/to/renderer
/ -> render -V ropdriver
or hbatch /path/to/hip/file
it just same. Only mread is useful to read file in current hbatch session.
